Swap out Wraith fan for something quieter?
idigweeds
Are the fans on AMD's Wraith coolers replaceable with a standard 92mm fan? As quiet as the Wraith fans are, I am still thinking about getting something even quieter.
@idigweeds did you ever find an answer to this? I'm in the same boat. Not sure if my fan is a lemon, but I definitely would not call it quiet. I found this that does claim the mounting holes are 80mm https://smallformfactor.net/forum/threads/wraith-stealth-height.1952/page-3
I do see a few fans out there with that config. For instance this http://www.frozencpu.com/products/6144/fan-313/SilverStone_FM83_92mm_Case_Fan_in_80mm_Mounting_Frame_w_Fan_Controller.html which may not be any quieter..
Also wondering an adapter like this could be used: https://www.amazon.com/Nexus-80mm-92mm-120mm-Converter/dp/B002C7IQ1O
but not sure introducing a gap like that between fan and heatsink is a bad idea.
There's also flat adapters like this to go...
There's also flat adapters like this to go to 92mm but can only find on ebay
https://www.ebay.com/itm/80mm-to-92mm-Flat-Fan-Adapter-Converter-change-mounting-PC-Modding-Mod-Custom/282270331744
Anyone have advice here or experience with adapters of this sort?
I have the wraith stealth cooler, which I imagine will be similar to the Spire. When I pulled the fan to rotate the AMD logo, I found that it matches the 80mm mounting. I -was- going to use an 80mm-120mm adapter, but because the adapter's hole is made for the 80mm fan it actually looked like I'd be getting less airflow. It also looked weird, so I just returned the adapter and put the stock fan back on.
