Swiftech H320 and Thermaltake Core V71
nyogisanz
28
Hi, I would just like to ask the opinion of the experts here basing from the specs included in these:
http://www.thermaltake.com/products-model.aspx?id=C_00002231
Swiftech H320
http://www.swiftech.com/H320.aspx
whether it is possible for me to do a push-pull configuration placing the swiftech at the top of this chassis without affecting the mobo (Asus Z87 pro and Ram G-skills Trident X 2400 heat spreaders)
I would also really appreciate any avenues/advice aside from the top to put the huge radiator of the swiftech or any better configurations.
Big Thanks
Well tnx anyway Ihog, appreciate it. In ur behalf, what do you think is the best config for this should the push pull config won't be possible? Sure don't want any dust accumulating in the rads or inside my case hehe
Anyway, one there who can comment whether a push pull configure is possible in this set up or can recommend the best set up or another case (the expensive ones are out, don't much have money for that hehe)
