Hello,
My company plans on building a system with the following NIC: Mellanox MCX653106A-HDAT
...and I was wondering whether it would work with the following switch: Arista 7050SX-72Q
https://www.arista.com/assets/data/pdf/Datasheets/7050SX-128_64_Datasheet.pdf
https://pasteboard.co/XkIEngOWVrIA.png
Even though the switch is older (and can't handle the high throughput of the Mellanox), the plan is to eventually replace the Arista (but for now, just use the Mellanox at a lower throughput),
I assume the Arista and the Mellanox should be able to auto-negotiate with one another, but one of the Engineers on my team mentioned that QSFP+ (on the Arista) couldn't work with QSFP56 (on the Mellanox).
In case the Mellanox doesn't work with the Arista, could someone recommend the highest throughput NIC that can work with the Arista?
Any help would be greatly appreciated.
Thank you,
Nelson
NVIDIA Mellanox: End-to-End Interconnect Networking Solutions
The leading supplier of end-to-end Ethernet and InfiniBand intelligent interconnect solutions and services.
store.nvidia.com
Thank you,
Nelson
