I have a LAN with one branch set up as follows:
Router -> Switch -> Switch -> GoogleTV, sat DVR, and XBox
All was was working fine... and then it stopped working. Nobody had touched it. While troubleshooting I discovered that if I bypass the second switch and plug the cable into any one the three devices, that device connected just fine. So I think "bad switch".
The new switch arrived today, but it didn't fix the problem. If I plug the cable leading from the first switch into the second, new switch, it doesn't even display the connection light. But if I plug it directly into one of the devices it works just fine. I tried different cables, but no success.
These switches don't have cross-over ports, so I don't think that's the problem. I've tried plugging the cables into different ports on the switches. That didn't help.
I'm out of ideas. Anyone have some suggestions that can lead me in the right direction?
Thanks!
Thanks!
