C Change_Later Commendable Feb 8, 2017 27 0 1,530 Mar 31, 2017 #1 Hi, just wanted to quickly ask if it is possible to take all the parts out of my Alienware Aurora R4 computer case and put it into the NZXT H440. Is anything too big or too small? Also, if it doesn't fit, what cases would fit the components? Thanks
Solution Dark Lord of Tech Mar 31, 2017 The board is a 2 component design , the motherboard and PSU are a proprietary setup.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,816 1,868 159,590 Mar 31, 2017 #2 It can't be moved to a new case the motherboard is proprietary.......Sorry. Upvote 0 Downvote
C Change_Later Commendable Feb 8, 2017 27 0 1,530 Mar 31, 2017 #3 But I've seen other people say you can as long as everything is the right size Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,816 1,868 159,590 Mar 31, 2017 Solution #4 The board is a 2 component design , the motherboard and PSU are a proprietary setup. Upvote 0 Downvote Solution
C Change_Later Commendable Feb 8, 2017 27 0 1,530 Mar 31, 2017 #5 What if I got a new motherboard ? Upvote 0 Downvote
