A couple of weeks ago my computer started running at about 5 fps max, and after exiting the game to restart my computer, it would not shut off. I ended up having to turn the PSU switch off just to get it shut it down and when it restarted it said that the problem was my CPU overheating. It was reaching 100 degrees Celsius but after taking it in for an inspection, there is no CPU damage, fortunately. They inspected my liquid CPU cooler and somehow it just up and died, and they say the reason it probably died within a year of me building this PC is because I have the radiator mounted vertically to the front of my PC instead of on the top blowing down, so it's working against gravity, however, I built a computer around 7 years ago with the same setup for the radiator and it didn't die in over 2 and a half years so I doubt that's really the culprit.
Just to be safe and not deal with this again, though, I was trying to figure out what I can do with the mount. The only reason I didn't put it on the top to begin with is because my RAM was too bulky for it to fit, and I think my ASUS motherboard had some clunky parts that blocked it as well. After talking to my friend and her boyfriend who both built their PC's, they asked me why I didn't just do a heatsink instead in the first place. They said they've never used liquid cooling and have never had their CPU's overheat. I'm not sure where to start with this, though, according to them even the most high-end heatsinks usually costs less than an average liquid CPU cooler so money isn't an issue, I just want what's gonna cool my CPU the best.
I'll have to measure to make sure it fits, but assuming it would, is there any issue just switching from liquid cooling to heatsink? I'd also have to look at my fan situation then, I assume, since I'd have nothing on the front. I have two 120mm (i believe) case fans on the top and one 120mm on the back, so could I just mount my two 140mm case fans on the front blowing in and then keep my 2 on top and 1 in back blowing out?
