Switching out fans for astetic purposes. I am wondering if the fans I found are better than the stock fans.
Replacement Fans, COUGAR 14CM Green LED Hydraulic (Liquid) Bearing Ultra Silent Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553014
Stock Fans, Corsair Air Series AF140 Quiet Edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181028
Replacement Fans - 1000 RPM, 73.2 CFM, 18 dBA, 1.4 Static Pressure
Stock Fans - 1150 RPM 67.8 CFM, 24 dBA, 0.84 Static Pressure
Here are my questions.
1. Are the replacement fans better than the stock fans?
2. Will the replacement fans push more air through my system?
3. Will the replacement fans be quieter than the stock fans?
Thank You!!
Thank You!!
