bought a Synology DS415+ online non working and when I plugged a new power supply in and held the power button for a few seconds the machine began booting up.
After a few minutes later the blue light is still flashing, so I shut it down and opened it up to get to the motherboard as I was going to do the solder fix for the bios clock, but I quickly realised it had already been done (poorly) but even worse was when I realised the bios cr1220 battery and holder was not on the motherboard and wasn’t in the case.
I managed to clean up most of the solder mess and now wondering which way I should proceed as the only thing I can think of is try to replace the battery holder on the motherboard
I’m not sure of if it needs a specific cr1220 battery holder or do I go with a 3V CR1220 Lithium Coin Cell Battery with Leads. (pic 6)
I would prefer the hard plastic ideally, also there are 2 small holes in centre where the holder sits over the motherboard, does anyone know if they are universal fit?
I have linked 6 pictures, picture 1 & 2 is of a clean motherboard which is perfect condition, pic 3 is of how I received it and pic 4 is of me removing the solder and pic 5 is as far as I went in clean up for now.
View: https://imgur.com/a/u7ltjp9
View: https://imgur.com/a/JzaeCNw
View: https://imgur.com/a/TkpJCod
View: https://imgur.com/a/DvkQ87G
View: https://imgur.com/a/fMtB4Mq
View: https://imgur.com/a/EQhEp9U
