[SOLVED] "SYS_FAN#" on Mobo has 4 Pins, Connector Cable Has 3 Holes?
MarsColonist
Commendable
Jan 9, 2021
105
9
1,585
Motherboard: MSI B550-A PRO
Case: Be Quiet! Pure Base 500DX
I was trying to get some case fans connected just now and noticed that the connector points I thought I was supposed to use on this motherboard seem to have 4 pins, but the fan connectors appear to only have 3 holes for these pins...
But those connector points on the motherboard, as you can see in the photos -- they are labeled "SYS_FAN" followed by a number... so those should be for case fans, right? It would seem... and yet the hole count doesn't match the pin count, so I suppose I can't/shouldn't try to connect them...?
View: https://flic.kr/p/2kGvV2Z
View: https://flic.kr/p/2kGsjii
View: https://flic.kr/p/2kGsjhm
Yes, you can connect 3-wire fans to the 4-pin header on the motherboard. Most modern boards have the option of either DC (3-wire) or PWM (4-wire) control. If your board doesn't have the option, the fan will simply run at full speed all the time.
The header is 'keyed' so you can only plug it in using the correct set of pins.
Reactions: MarsColonist
