Archived from groups: rec.games.pinball (
More info?)
If Volcano is the same as BH (only Sys80 schematic I have) that coil
should be an A-16570 (same coil for the ball gate as for the outhole).
Replace it, and I believe your problem will be solved.
When I got my BH, it had A-1496's in it for both the outhole and ball
gate. Both were problems (both blew fuses, ball gate ran warm, outhole
kill a transistor on the driver board) until I replaced them with the
correct coils (A-16570). No problems whatsoever since.
My theory is that since the A-1496 was the most common coil for
Gottleibs of the era, slack-ass repairmen only bothered carrying that
coil. So any coil that got replaced was replaced with an A-1496.
The problem is that an A-1496 has a nominal resistance of only 2.95
ohms, whereas an A-16570 has a nominal resistance of 15.5 ohms. Ergo,
if an A-1496 is placed in the ball gate circuit, it will draw over 5
times the current it was designed to (and thus blow a lot of fuses).
So, get yourself an A-16570. And while your at it, buy a
manual/schematic for your game--much good info in them.
Darren
