[SOLVED] System Blue Screens once every morning
Egossi
Commendable
Dec 11, 2019
18
I have no idea why or how it happens, but ONCE every morning or two my PC blue screens with the error message DRIVE_STATE_FAILURE after using it for about 5 minutes, i havent cared too much about it since after it restarts its always perfectly fine for the rest of the day, but i figured i should ask
Specs:
Power Supply: Corsair CV650
Motherboard: MSI B550M PRO-VDH (WiFi)
CPU: AMD Ryzen 5 5600X
GPU: HIS AMD Radeon RX580 ICEQX2 OC 8GB
Case: Dark X-Force Mid-Tower
RAM: Corsair Vengeance LPX 16GB (2x8GB DDR4 3600MHz)
SSD: Samsung 850 EVO 500GB
Second SSD: SanDisk Plus 480GB
CPU Cooler: Wraith Stealth (Stock)
Monitor: LG 22MP57HQ-P IPS 22" 5ms 1920x1080 60hz
Second Monitor: Asus VS197NE 18.5" 5ms 1366x768 60hz
OS: Windows 11 Pro
Conversion of dumps
report - Click run as fiddle to see report
File: 100422-7171-01.dmp (Oct 4 2022 - 18:44:44)
BugCheck: [DRIVER_POWER_STATE_FAILURE (9F)]
*** WARNING: Unable to verify timestamp for BthPS3.sys
Probably caused by: BthPS3.sys (Process: System)
Uptime: 0 Day(s), 15 Hour(s), 47 Min(s), and 52 Sec(s)
File: 100322-8453-01.dmp (Oct 3 2022 - 19:05:31)
Uptime: 1 Day(s), 8 Hour(s), 55 Min(s), and 59 Sec(s)
File: 100222-8640-01.dmp (Oct 2 2022 - 10:08:08)
*** WARNING: Unable to verify...
You forgot to mention the make and model of your PSU. Please include the age of the unit as well. As for your platform, have you tried reinstalling your chipset drivers in an elevated command, i.e, Right click installer>Run as Administrator? BIOS version for your motherboard at this moment of time?
Oh it's a Corsair CV650 80+ bronze, less than 2 years old
i havent tried reinstalling chipset drivers
BIOS version should be whatever the latest one was in november 2021 cause i flashed it myself and thats when i bought it
I also forgot to mention my storage, I edited the main post with all the specs
Can you follow option one on the following link - here - and then do this step below: Small memory dumps - Have Windows Create a Small Memory Dump (Minidump) on BSOD - that creates a file in c windows/minidump after the next BSOD
  1. Open Windows File Explore
  2. Navigate to C:\Windows\Minidump
  3. Copy the mini-dump files out onto your Desktop
  4. Do not use Winzip, use the built in facility in Windows
  5. Select those files on your Desktop, right click them and choose 'Send to' - Compressed (zipped) folder
  6. Upload the zip file to the Cloud (OneDrive, DropBox . . . etc.)
  7. Then post a link here to the zip file, so we can take a look for you . . .
https://anonfiles.com/z1aac8B5y9/083022-7140-01_zip
Conversion of dumps
Uptime: 0 Day(s), 13 Hour(s), 58 Min(s), and 38 Sec(s)
File: 100122-10312-01.dmp (Oct 1 2022 - 20:07:30)
Probably caused by: BthPS3.sys (Process: software_reporter_tool.exe)
Uptime: 3 Day(s), 18 Hour(s), 49 Min(s), and 36 Sec(s)
File: 083022-7140-01.dmp (Aug 31 2022 - 03:25:05)
Probably caused by: memory_corruption (Process: System)
Uptime: 0 Day(s), 17 Hour(s), 35 Min(s), and 50 Sec(s)
Most times I don't get any driver names to figure out cause, all yours say its same driver
All caused by
BthPS3.sys - my guess Bluetooth PS3 controller drivers
Jul 30 2021 BthPS3.sys
Jul 30 2021 BthPS3PSM.sys
either uninstall or update.
I don't know if this one is newer - https://vigem.org/Downloads/
that is probably 7C95v29 which might have been in beta that month due to win 11 coming out previous month, its actually dated January 2022.
You only 2 BIOS behind but since BSOD tells me what cause is. I don't think BIOS update would help. Last 2 just made changes so MB can run 5800x3d or Win 11.
All caused by
I knew I shoulda just bought an xbox controller, the third party drivers for ds3 are not very reliable, thanks for identifying the problem
