Today after i started my pc,it booted into windows normally,then when it was at the desktop it suddenly crashed and restarted.
When it attempted to restart there was no display-i turned it off and then back on a few times manually but to no avail(had to use the psu switch for turning it off as it doesn't switch off when i use the power button on the case).
After a few tries when i started it again,it turned on and then immediately back off and this went on and on so i turned the pc off via the power switch on the psu.Since then whenever i switch the computer on,it bootloops in this manner (ie turns on and off repeatedly),much to my frustration.
Something similar had happened a month or two ago(ie the bootlooping but in that instance there was no system crash) but it went away on its own after a while and so i wasn't too bothered by it at the time.
What could be causing the issue, is it the PSU ?
I have observed that this issue tends to crop up whenever the system is switched on after a span of 4-5 days,which is really weird.
Here are the specs for reference:
Asus ROG Strix B365-G
i5-9400f
Zotac 3060 Ti
8*2 corsair ddr4,
Corsair T-XM 750
The PSU was bought in 2020 - - - should i send it for RMA?
i5-9400f
Zotac 3060 Ti
8*2 corsair ddr4,
Corsair T-XM 750
