System build compatability
Aug 31, 2018
Hi, I was wondering if someone could please tell me if the parts in my build would be 100% compatable.
Gpu: Asus Gtx 1060 3gb of edition
Power supply:EVGA supernova 750 g3 fully modular
Ram: Corsair vengance lpx dram 2666mhz c16 memory kit for systems 8 gb ddr4 2666(pc4 21300)
Mobo: Gigabyte b360m ds3h m/atx
CPU:Intel 8th gen core i5-8400
Yes, they all look good. The 750 G3 is a bit overkill. If you could save enough for a GTX 1060 6GB by going with a 550W instead then do that.
