System Build Compatibility
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($339.99 @ Amazon)
Motherboard: ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard ($129.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($75.60 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($79.99 @ Amazon)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card (2-Way CrossFire) ($538.99 @ SuperBiiz)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: SeaSonic M12II 850W 80+ Bronze Certified Semi-Modular ATX Power Supply ($119.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.99 @ Newegg)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter ($37.33 @ Amazon)
Headphones: Logitech G230 Headset ($35.99 @ Amazon)
Total: $2013.84
this will give you WAY better performance.
EDIT forgot a cpu cooler, through one in if you want.
I have some big plans with all that RAM. I will not go over $2000. I really don't need many fans actually.. I just have a fan.. so new link: http://pcpartpicker.com/p/fvQbCJ edit: also, I've never built a computer but I have plans to host servers and use tons of ram for several tasks, powerful GPU and CPU for crypto-currency mining.
if you want 32gb ram, then do this PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($339.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Memory: G.Skill Ripjaws X Series 32GB (4 x 8GB) DDR3-1866 Memory ($315.98 @ Newegg)
Video Card: XFX Radeon R9 290 4GB Double Dissipation Video Card (2-Way CrossFire) ($384.99 @ Newegg)
Total: $1976.20
that i7 is FAR better than the 9590, and uses 1/3 the power and stays cooler.
Is that the build you're currently using?
I've played around with computer parts for a while and I've decided I'm ready for a new gaming/mining rig :) Server stuff too.. thank you!! (I don't really need the CD-Drive though, I can re-use my old one.)
