Hey guys,
I am build a new system from scatch and needs some input. I did all the research about a year ago but ran into some life issues that delayed the build. but ready to continue. using most of the research from a year ago here is a system I threw together and need some critical input.
System function: primarily gaming
Budget: honestly I would like to stay about 1000.00 how ever I hate skimping when it comes to builds, so I can strech that if needed to more of a 1500 range. But any inpute to reduce cost would be appreciated.
Core: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Mobo: ASRock Z77 OC Formula LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 SSI CEB Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157328
Ram: CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233143
GPU: EVGA SuperClocked 02G-P4-3662-KR GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130810
Power Supply: CORSAIR HX Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
HDD: Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case with Upgraded USB 3.0
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
OS: soft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Optical:what ever is cheapest, this gets used hardly at all. mainly just for windows. - ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
I apologize if I missed something or made some idiotic error with matching componets I have been out of the game for a while.
Total as of right now sits at 1300 roughly. with input I hope to gain either better optimization of componets performance wise or something more cost effective with only a minor dip in performance.
Thanks for any and all input.
DG
DG
