Motherboard -MSI 760GMA-P34(FX) AM3+ AMD 760G SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
> http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU -AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor FD6300WMHKBOX
GPU -ASUS HD7790-DC2OC-1GD5 Radeon HD 7790 1GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready CrossFireX Support Video Card
RAM -Crucial 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CT51264BA160B
PCU -LEPA N Series N500-SA 500W ATX12v Power Supply
> http://www.newegg.com/Product/ProductList.aspx?Submit=E...
HDD -WD BLACK SERIES WD1003FZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
> http://www.newegg.com/Product/Product.aspx?Item=9SIA2W0...
Display -Asus VS247H-P 23.6-Inch Full-HD LED-Lit LCD Monitor
> http://www.amazon.com/Asus-VS247H-P-23-6-Inch-Full-HD-L...
Keyboard -Logitech G110 Black USB Wired LED Backlighting Gaming Keyboard
I am considering replacing several parts...
Motherboard
MSI 970A-G43 AM3+ AMD 970 + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=13-130-679
PSU
SeaSonic S12II 520 Bronze 520W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
GPU
MSI GAMING N750Ti TF 2GD5/OC GeForce GTX 750 Ti 2GB 128-Bit GDDR5 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127783
RAM
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
To make a long story short, this build will come to fruition in the next week and I am been "swept up" so to speak between finding new deals/better parts. This was supposed to be a build in the range of 500 USD, but I am having trouble not expanding that range in order to add a little upgrade-ability in time. Any tips or ideas would be greatly appreciated.
Motherboard
PSU
GPU
RAM
