[citation][nom]cleeve[/nom]Yeah, the thing is I'm just not one of those people who assumes that only name brands have exclusive rights to make anything worthwhile.[/citation]
You missed my point, and went for the cheap shot, assuming I'm a brainless fanboy. I am not. The Antec case has been tested, reviewed, and put through numerous builds multiple times. This is the first time I've heard of this Rosewill case on a website that writes reputable reviews of computer equipment. When the difference in price is as small as this (right now, the Rosewill case is 39.99 on newegg, the Antec is $64.99). For my $25, I'm going to go with the case that reviews well, that I've built in numerous times before, and that I know will perform well. I don't have $40 to blow hoping for a pleasant surprise.
Now, I don't, and probably never will, wear a Rolex. The extra bit of quality you get is definitely not worth the extra cost. The Three Hundred is hardly the 'Rolex' of cases. Read around the Internet for a bit, and you'll see that Antec is known for it's value and low cost, and the Three Hundred is one of their lower cost cases. I couldn't give a flying f*** what brand the case is, just so long as several reputable individuals have good things to say about it. I've used Kingwin cases (when they did OEM work for Antec). If I tried to recommend Lian Li, or something, then you'd have every right to chide me the way you have, but, we're going for best bang-for-buck, right? In my mind, the Three Hundred is the right choice.
Go back and read the latest $625 system build writeup. Look here:
http://www.tomshardware.com/reviews/overclock-e5200-radeon,2144-6.html
[citation][nom]TFA[/nom]removing the side panel of the case dropped CPU load temperature as much as eight degrees. It seemed that our budget case didn’t have sufficient and proper airflow for this level of overclocking and it simply paled in comparison to the Antec Three Hundred we’d been using.[/citation]
So, they took 2 shots with budget cases of unknown quality. One was somewhat of a failure (they recommend adding another intake fan. That's eating right into the money you save by going with the cheapest option - a coworker of mine would call this "polishing a turd".) I'm saying that, for my money, I'm going to buy something I know will perform well. $25 extra on a $1,250 build is hardly pandering to the overpriced brand names.
