That is the ugliest case I've seen in a long time. No rotated hd bays or bottom mounted psu. Expansion slots at the back are snap off instead of reusable, and screw in on the outside. No CPU access at the back and only one 120mm space at the rear, none on the top. But you do get one tacky red fan that will be louder than your whole system combined.
Seriously folks, the NZXT GAMMA Classic Case is the best ATX case for under $50.
Also I agree, 64GB SSD is tiny for gamers. Its fine in an office enviroment, where you only have just the production programs that you use on a daily basis installed, with the actual data stored on a server/database. But for gamers whose Steam folder alone is in the 100s of GBs, its pointless.
Also, why bother with an aftermarket heatsink if you don't plan to overclock? I can understand if your after a low/noiseless pc (like me), but considering your running a 7970 and noisy stock case fan, it's a waste of money.
On a positive note, the $650 build was OK.
