Happy New Year!
Just a simple system check for you guys in the know. I wasn't able to get the GPU I wanted at the time due to shortage etc. And it was suggested that the i5 12600K was the best price at the time unless I as going i9. I currently have the following specs and just wanted to get input from the pros as to where I stand. Again my inquiry is more aligned to CPU, GPU and operating system.
i5-12600K
ASUS ROG STRIX Z690-A
G Skill Ripjaws V 64gb DDR 4 ( 4-16GB)
ASUS GeForce RTX 3060 12B GDDR6
850W Corsair RMx Series 2021
Artic Freezer 34 eSports DUO
(2) 2TB Samsung 980 Pro SSD
Odyssey G49
Windows 10 x64
Full Case - Old Area 51 Alienware
Approximate Purchase Date: ASAP
Budget Range: Open no restrictions (Within reason)
System Usage from Most to Least Important: Gaming, Hi Def streaming and the use of multiple, programs simultaneously.
Are you buying a monitor: No
Parts to Upgrade: CPU and GPU
Do you need to buy OS: Yes Windows 11 Upgrade?
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts: Amazon
Parts Preferences: Intel
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: 5120 X 1440
Additional Comments: I would like to make sure I am making use of all the hardware bandwith I have availible and not limited on anything that would be hindered by 1 or 2 parts that restrict the same.
And Most Importantly, Why Are You Upgrading:Keeping up with technology advancements.
i5-12600K
Odyssey G49
Windows 10 x64
Overclocking: Maybe
