G
Guest
Guest
While replacing CMOS battery is the most obvious solution to solve the slowing PC clock, it did not help in my case.
The PC clock slows down after I power it down and restart after a few hours. The gap is small, about 5 - 7 minutes behind.
I have not yet tested it by keeping it off for days if the gap further increases.
I have already replaced CMOS battery but issue persists.
The strange part is that the clock otherwise seems normal when PC is running . The issue comes only after switching it off and then on after a few hours.
Also just note that Windows time sync feature is irrelevant here as the issue is at BIOS itself. Before booting into Windows I purposely boot to BIOS and check the clock, to find it behind by 5 - 7 minutes.
I am really curious to know what might be going wrong in this case. Thanks.
