System configuartion for designer
Manoje
4
Hello,
I would like to know which asus motherboard will be compatible for i7 920 processor. And remaining configuration also for using the applications of Adobe CS4, 3d Max 9, corel draw.
Hi newcomer and welcome to the Tom's hardware forum.
1- What is your budget?
Mobo: Asus P6T Deluxe V2 or THIS if the budget isn't important
GPU: GTX285 or better. Or 5850 or better
RAM: 6GB (3x2GB) CL7 or CL8
HDD: Spinpoint F3 1TB or SSD
PSU: 500W-600W if you only run a GPU, for SLI or X-Fire you need 700W
