Yes everything heats the air in the case.
GeForce 660 GT clone (128MB video RAM)?
Graphics Processor: nVIDIA GeForce FX 5200
Well thats the same as mine and yes it gets quite hot, but not as hot as the new cards as the transistor density is way more.
The more transistors = more heat
same for the GPU and the CPU.
TWIN CORE = TWICE THE NUMBER OF TRANSISTORS.
Be aware that the stock fan supplied with such CPU's by the manufacturer
is concidered sufficient to cool it, providing you are venting the case
in an adequate manner. Tom did a review...educate yourself.
http://www.tomshardware.com/cpu/index.html :arrow:
Intel's Core Duo is worth serious consideration if you care about performance, low noise and high efficiency in a PC system. We compared it to efficiency specialists Pentium M and Turion 64, but found the Athlon 64 X2 to be a potential show-stopper.
