Hey guys.
As the topic says I have a really strange problem lately.
I have a EpoX EP-8RDA6+pro motherboard (3 dimms) and had a total of 1 GB ram (1 x 512 Kingmax and 2 x 256 TwinMos). Everything worked fine until one day i decided to get a 2 x 512 kit (also TwinMos) to replace the old 2x 256. This worked fine for a few days until one night. I was watching a movie and had a sudden reboot.
The computer froze at the memory and IDE diagnostic screen. I manually rebooted and had the same problem.
After a while i decided to remove the kigmax module and run 1 GB dual channel. This also worked fine for a week or so and after that the restart-crash-restart cycle hit me again.
Now the only way i can actually boot normaly is by setting FSB at 100 (i have a athlon xp 2100+) and working only with 1 ram module. If i try to add another ram module the comp crashes again (doesnt matter if its dual channel or not or if its a 512 or 256).
I tried a bios rewrite, latest version, heat doesnt seem a problem at only 48" C, but nothing works. I also tried to mount the old 2 x 256 + 1 x 512 modules but i still experience crashes.
Tried to find a answer but had no luck so far 🙁
i will keep you updated in case i figure out the problem.
