[SOLVED] System crashing due to several BSOD errors encountered ?
ApexDorifto
33
Hello everyone!
I'd like to address about my PC throwing BSODs.
Problem/s
  • WHEA_UNCORRECTABLE_ERROR
  • *DPC_WATCHDOG_VIOLATION
  • *DRIVER_STACK_OVERRAN_BUFFER
  • These BSOD errors occurs at random times, but I have observed that it usually appears when:
    • I'm editing my videos using DaVinci Resolve 20
    • Playing games (rarely for BSOD to occur)
PC Specs:
Part​
Brand/Model/etc.​
Part/Serial No.​
CPU
Intel i5-8400 (with Intel Stock Cooler)
GPU
Gigabyte AORUS RX 570 (4GB)GV-RX570AORUS-4GD
MOBO
Gigabyte H310M H 2.0
RAM
Slot 1:
Samsung Kingston 8GB 2666MHzKF2666C16D4
Slot 2:
SK Hynix V-Color 8GB 2666MHzTD48G26S819-VC
SSDHikvision 240GBHKVSN HS-SSD-C100/240G
HDDWestern Digital 1TB (Green)WDC WD10EURX-63UY4Y0
PSUThermaltake TR2 S 600W
Troubleshoots I've Made
  • Re-applying thermal paste on my CPU
  • Stress tested my CPU using Intel Processor Diagnostic Tool
    • NOTE: Did not show any BSOD
  • Checked CPU temperatures
    • NOTE: reaches around 42°C at idle; ~75°C-80°C at full load.
  • Checked GPU temperatures
    • NOTE: reaches around 47°C-50°C at idle; 80°C at full load.
  • Checked CPU and GPU clockings
    • NOTE: Everything is at default, none are overclocked.
  • Reset BIOS/UEFI settings to "Default"
  • Checked RAM Timings at GIGABYTE UEFI
    • NOTE: Everything is at "Auto"
  • Ran several commands in CMD/Windows Powershell
    • sfc /scannow
    • DISM /Online /Cleanup-Image /RestoreHealth
    • mdsched (no errors)
  • Tried to use PC one RAM stick per RAM slot
    • NOTE: I used DaVinci Resolve to let the BSOD appear whjle doing this troubleshoot.
  • *Reinstalled AMD Radeon Software for GPU
RAM Stick/Slot​
Time of BSOD Appearing​
Time Duration between Boot Time and Time of BSOD Appearing​
SK Hynix @ Slot 1​
8:39 AM​
8:54 AM​
~15 minutes​
SK Hynix @ Slot 2​
9:03 AM​
9:17 AM​
~14 minutes​
Kingston @ Slot 1​
9:22 AM​
9:41 AM​
~19 minutes​
Kingston @ Slot 2​
9:49 AM​
9:57 AM​
~8 minutes​
*Minidump Files
Here are the Minidump files after BSOD crashes.
Windows Minidump Files (Google Drive Folder)
If I need to do something to troubleshoot more or any questions need to be answered, let me know, any help will be greatly appreciated, thanks in advance!:bounce:
*EDIT: I've added the other BSOD errors that occurs, reinstalled GPU software. And also, added new minidump files that were newly created due to BSOD occurring again.
UPDATE
It's been weeks ever since I've posted my last update with my PC.
So far, my PC hasn't thrown any BSODs.
I assume that one of these methods has fixed the BSOD issues.
  • Performing a clean installation of Windows
  • Uninstalling VALORANT and Riot Client
  • Not using one of the suspicious USB port in the front panel of my case (covered it also with duct tape to prevent any connections)
  • Setting my maximum processor state to 99% in Power Configuration Plan (High Performance).
MOBOGigabyte H310M H 2.0
What BIOS version are you on for your motherboard?
RAM
Slot 1:
Samsung Kingston 8GB 2666MHzKF2666C164
Slot 2:
SK Hynix V-Color 8GB 2666MHz (TD48G26S819-VC)TD48G26S819-VC
Looks like the Kingston stick might be at fault or the memory controller on your processor is having trouble with said Kingston ram stick. I would also advise against mixing and matching ram sticks, they are usually the cause for instabilities.
That's a horrible PSU.
Mixing different RAM is always a bad idea. RAM should always be purchased in a pack of matched sticks. In addition, I'm getting bad symbol errors on four of your dumps and a fully corrupted dump in the other. These are also strong indicators of a RAM issue.
I would definitely remove whichever RAM stick was the most recently installed, at least until this issue has been resolved. That said, you seem to be getting BSODs on only one stick, so RAM isn't the whole story here.
The other common cause of dump corruption is a flaky system drive. I'm not familiar at all with Hikvision SSDs but check to see whether they have a diagnostic tool. If they do then run the maximal diagnostic they have on the drive. If not, then upload the SMART data for the drive, a tool like CrystalDiskInfo can show you that. Post the SMART data here if you like.
I'm also a bit concerned about your CPU. The stock Intel coolers are barely adequate, I would never recommend using one. Even though your "full load" test only reached 80°C it's quite possible that you may have exceeded the 100°C Tmax temp at times, especially if you're gaming.
I would also help if you copuld please download the SysnativeBSODCollectionApp and save it to the Desktop. Then run it and upload the resulting zip file to a cloud service with a link to it here. The SysnativeBSODCollectionApp collects all the available troubleshooting data and will make diagnosing your problem much easier. It DOES NOT collect any personally identifying data. It's used by several highly respected Windows help forums (including this one). I'm a senior BSOD analyst on the Sysnative forum where this tool came from, so I know it to be safe.
You can of course look at what's in the zip file before you upload it, most of the files are txt files. Please don't change or delete anything though. If you want a description of what each file contains you'll find that here.
RAM
Slot 1:
Slot 2:
I've checked my BIOS version and it says "F2".
(I'm also pretty sure that the BIOS version isn't the issue here because I've been using this motherboard on the same BIOS version ever since we bought this PC, and no problems we're occuring up until the BSOD appeared from last month up until today.)
Unfortunately, I don't have any spare RAM sticks, that's why I can't prevent doing mix-matching with my current RAMs, and also determine which RAM stick is at fault.
Maybe these pictures will help.
I did changed the position of the RAM sticks just a few moments ago.
Yes, my older brother and I we're both suspecting that one of the RAMs are failing now ever since it was bought. The SK Hynix was the older one compared to my Kingston RAM stick. I didn't had any idea at that time when I bought the RAM stick (Kingston) which is completely my fault.
Here's the SMART data of my SSD and HDD
best guess is overheated cpu
all the bugchecks were called by the CPU.
I would be looking for a overheated cpu/ fan that is not working. Then I would look at the power supply and confirm that the levels are correct (see if the bios will report the voltages)
your build has various problems that need to be addressed. modified windows core files, old bios, old drivers. suspect drivers installed but I would check cpu temps/voltages as a direct cause of the bugchecks.
I did not see a driver issue that would cause this bugcheck. Ram sticks should not cause this problem.
last bugcheck called by cpu after 18 minutes of uptime.
debugger does not like your build. various issues.. will take a quick look at the other dumps.
second bugcheck same as first
System Uptime: was 8 minutes
third bugcheck same as others, system uptime 25 minutes
4th bugcheck same as others, system uptime 19 mins
5th bugcheck same as others. system uptime 13 minutes
notes:
\SystemRoot\System32\Drivers\WinRing0x64.sys Sat Jul 26 06:29:37 2008
win32kbase.sys Wed Nov 7 17:02:09 2001
\SystemRoot\System32\DriverStore\FileRepository\heci.inf_amd64_85021432489d6a1c\x64\TeeDriverW8x64.sys Thu Apr 4 02:38:40 2019
\SystemRoot\system32\drivers\RTKVHD64.sys Tue May 14 04:25:05 2019
\SystemRoot\System32\drivers\RtkBtfilter.sys Wed Oct 31 18:51:00 2018
\SystemRoot\System32\drivers\rt640x64.sys Mon May 10 20:30:41 2021
\SystemRoot\system32\drivers\rawaccel.sys Sat Sep 18 03:42:08 2021
C:\Windows\system32\drivers\MsIo64.sys Sun Jan 19 19:35:15 2020
\SystemRoot\system32\drivers\iriuna0.sys Thu Oct 22 08:22:10 2020
C:\Windows\system32\drivers\IntelHaxm.sys Tue Aug 25 03:11:09 2020
SystemRoot\System32\drivers\dtlitescsibus.sys Mon Nov 12 19:11:07 2018
SystemRoot\System32\drivers\dtliteusbbus.sys Mon Jul 26 11:43:47 2021
C:\Windows\system32\drivers\CtiIo64.sys Tue Apr 26 20:01:30 2022
\SystemRoot\system32\DRIVERS\bddci4.sys Fri Feb 7 02:51:15 2025
SystemRoot\System32\DriverStore\FileRepository\atihdwt6.inf_amd64_5bf3de4243c61001\AtihdWT6.sys
C:\Users\ADMINI~1\AppData\Local\Temp\ALSysIO64.sys Tue Oct 18 07:38:31 2022
1: kd> !sysinfo machineid
Machine ID Information [From Smbios 3.1, DMIVersion 0, Size=4557]
BiosMajorRelease = 5
BiosMinorRelease = 12
BiosVendor = American Megatrends Inc.
BiosVersion = F2
BiosReleaseDate = 06/22/2018
SystemManufacturer = Gigabyte Technology Co., Ltd.
SystemProductName = H310M H 2.0
SystemFamily = Default string
SystemVersion = Default string
SystemSKU = Default string
BaseBoardManufacturer = Gigabyte Technology Co., Ltd.
BaseBoardProduct = H310M H 2.0
BaseBoardVersion = x.x
1: kd> !sysinfo cpuinfo
[CPU Information]
~MHz = REG_DWORD 2808
Component Information = REG_BINARY 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Configuration Data = REG_FULL_RESOURCE_DESCRIPTOR ff,ff,ff,ff,ff,ff,ff,ff,0,0,0,0,0,0,0,0
Identifier = REG_SZ Intel64 Family 6 Model 158 Stepping 10
ProcessorNameString = REG_SZ Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
Update Status = REG_DWORD 0
VendorIdentifier = REG_SZ GenuineIntel
MSR8B = REG_QWORD b400000000
cpu released in October 2017
notes:
BiosVersion = F2
[CPU Information]
I've been monitoring for weeks about my CPU temperature and it seems stable, I even stress-tested it several times and it didn't BSODed, neither the PC restarted itself (usually when TJunction is reached).
Same as the +3.3V, +5V, and +12V. I've been checking HWiNFO64 to monitor those voltages.
I also have several .CSV log files generated by HWiNFO64.
UPDATE:
After few weeks, several error codes appeared on my PC. I'm leaning towards the CPU as the root problem of my computer, but I'm still quite not sure. I've also updated the Google Drive folder by uploading the new generated minidump files (All of them are generated the same day "42725").
Minidump Files (as of April 28, 2025)
I would boot into bios and check the system date and time to see if it was reset to defaults. (in case battery died and you lost bios config, resulting in incorrect memory timings)
if the bios info looks good, you could boot memtest86 and test memory timings. if memory timings are ok, then start to fix the other issues (below)
(have to run a errand, will look at another dump when I get back)
I would, remove some suspect driver, turn off the virtual memory reboot and turn it back on. Then run cmd.exe as an admin then run
dism.exe /online /cleanup-image /scanhealth
then reboot, update bios, then update the motherboard drivers.
looking at the most recent bugcheck.
system up for 45 min, access violation, corrupted stack, symbols not found.
I would remove
intel hardware accelerated execution manager.
i might suspect:
gvm.sys Thu Dec 8 13:07:37 2022
(android emulator for amd processor, your cpu is intel)
C:\Users\ADMINI~1\AppData\Local\Temp\ALSysIO64.sys Tue Oct 18 07:38:31 2022 (driver running out of hidden temp directory)
old bios:
I would remove
i might suspect:
old bios:
Looked at the second latest bugcheck. system up for 20 minutes.
bugcheck 0x124
I assume it is a bad overclock from your overclock driver.
(remove overclock driver)
trying to look at info shows info paged out to pagefile.sys.
debugger can not find proper symbols for your build.
!errrec debug function did not like the returned data structures.
0: kd> !sysinfo cpuspeed
CPUID: "Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz"
Rated Speed: 2800
Measured Speed: 2808
shows a overclock. guessing that IntelHaxm.sys
is doing some bad settings.
third bugcheck, system up for 31 minutes
heap corruption, in store.
can not validate the page frame since the symbols do not match.
maybe: update bios, cpu chipset drivers, turn off virtual memory and turn it back on to dump the pagefile.sys and make a new one.
run crystaldiskinfo.exe and read the smart data from the drive to get an idea of the health of the drive.
I would reinstall windows to get a valid build, without modified kernel files.
(or attempt dism.exe repair)
  • Removed Intel Hardware Execution Manager (intelhaxm.sys)​
  • Checked the date and time and also the settings in the BIOS/UEFI of my Motherboard​
    • The date is accurate and all of the settings are at default.​
  • Ran DISM.exe /online /cleanup-image /scanhealth
    • Result: No component store corruption detected, the operation completed successfully​
The PC BSODed after attempting the first DISM.exe /online /cleanup-image /scanhealth in CMD (I uploaded the minidump file)
I rebooted the PC again, I ran the command again and the result was successful.
EDIT:
I've checked WhoCrashed to check if there's any different result when my PC BSODed, and this was the result.
I've also uploaded the memory dump file as I'm typing the edit of this post.
Also, ALSysIO64.sys is part of the Core Temp tool, one of the tools I'm using for monitoring temperatures.
to be more clear, user mode service tried to read something from the file system cache, the cache manager was called, the the windows memory manger tried to prefetch pages and later ended up getting a bugcheck. it could just be something wrong in the storage, like a corrupted pagefile or bad drivers/malware.
I can not trust the symbols since the debugger does not like your version of the kernel or your crash dump.
you might google "how to force windows to delete the pagefile.sys on system reboot" then make the registry setting and reboot. It can help dump malware from the pagefile.sys.
cpu did call the bugcheck, the data structure could not be read from memory dump file. the symbols are wrong but it looks like the stack shows windows cache management and memory management calls before the bugcheck.
I would assume the cpu did a panic bugcheck and ended up saving a corrupt memory dump.
system was up for 10 minutes. I would be looking for incorrect voltages to the cpu or overheated cpu or stopped cpu fan.
(or overheated power supply or stopped psu fan, anything that could make the voltages wrong)
you might consider, google how to force a memory dump using a keyboard. make the registry change and force a memory dump on the working system. Just to confirm you can get a dump that is not corrupted.
you might consider booting up your system on a windows install image without doing a install, just to see if the cpu crashes.
(or boot into bios and leave the system to see if the cpu crashes)
if the cpu does not crash, I would make sure the bios is updated and the cpu chipset drivers are updated. because of the corrupted memory dump. after that I would look for corrupted pagefile.sys (bad cpu driver/malware) you can turn of windows virtual memory and reboot. windows will create a internal RAM pagefile in this case. You then can see if the system runs longer, if it crashes you will not get a memory dump in this case.
after that I would be looking at pulling the cpu, checking for bent motherboard pins/ burnt pens on the back of the cpu, and bad/old cpu paste.
I assume you have check to see if the bios is reporting proper voltages from your power supply.
bugcheck 0x124 with parameter 1=0 means the cpu called the bugcheck.
I can take a quick look to see it the !errrec command works
Reactions: ApexDorifto
UPDATE
Apologies for re-opening this thread again. Unfortunately, I'm being bombarded with BSODs again. I'm still wondering what could be the cause of the problem. I've uploaded the newly created minidumps below. (All of them are generated from day "042925" to "050125").
EDIT:
Unfortunately, it says that the 050125 minidump files won't let me upload to google drive, neither can be viewed with WinDBG, as it says that I have no permission to do so, even though I am using the administrator account.
Also, I've ran MemTest86 with both of my RAMs installed. Below are the results.
Minidump Files (as of May 01, 2025)
overall, looks like overheated cpu causing the cpu to crash.
if this is not a overheating/power issue then update the bios to version F14a
to pick up the microcode fixes to prevent cpu hacks. then run your dism.exe command or reinstall windows to get the system stable. (checksum errors in windows files) code running from kernel address but not from inside a known windows module or named driver.
I looked at several more minidumps.
overall my first guess is overheated cpu.
(check fan)
second guess would be improper power to cpu.
(i did not see any overclock drivers installed, bios had a very slight overclock by 8Mhz.)
very old bios version installed. I suspect if you boot into bios and leave the machine on, it will still crash while in bios. check the fans and power, if the machine is stable you will eventually want to update the bios and motherboard drivers and apply cpu firmware updates.
then attempt to fix your windows install by deleting the pagefile.sys and making another one. then run cmd.exe as an admin and run
dism.exe /online /cleanup-image /restorehealth
note: bunch of the bugcheck showed kernel address that looked valid but were not. this can indicate that the memory timings are wrong and you should run memtest86 to test. I would check the bios system time and date to see if it is wrong (indicating that the motherboard cr2032 battery has failed and the bios went back to defaults)
most current minidump looked like a driver bug,
(will take a look at the kernel dump to see if i can figure out the driver)
kernel dump was a bugcheck 0x124.
looks like a usermode program made a call, and the there was some problem in cache management and the window memory manager before the bugcheck.
debugger does not like your memory dump, can not find proper symbols/ check sum errors.
since the machine is old, I would boot into bios, check the system date and time and make sure the motherboard battery did not die. (time will go to default)
then check the cpu fan and blow out dust and make sure the fan is spinning.
boot into bios and check voltages for 3.3v 5.0v and 12v to make sure they are within 10 %
make sure your fan in the psu is working.
the system up time was 10 minutes, it could indicate overheating of the cpu or the psu.
machine info:
BiosVersion = F2
the first bugchceck error code indicated an access violation.
the data at the memory location is incorrect, you do not know why.
the second bugcheck looks like it has valid kernel address but they are not.
Normally, you would first update the bios to get the best default memory timings, set your memory profile then test your memory by booting memtest86 and running the test.
I would also update the cpu chipset drivers, delete the pagefile.sys by turning off windows virtual memory and turning it back on again.
(just for the case where the problem is in virtual memory (pagefile.sys))
you might even download a utility like crystaldiskinfo.exe and read the smart data from the drive to see if it is having errors.
turn off any overclocking, make sure you do not have two overclocking drivers installed.
will take a quick look at some dumps in a minute.
(check fan)
machine info:
BiosVersion = F2
I've also dealing with Hardware Errors when checking Reliability History in my Windows, I've added the 2 Watchdog dump files that were generated and also 1 minidump file that was generated between those 2 Watchdog dump files.
first watchdog timeout
was in the gpu, looks like it stopped responding and directx tried to reset the card but it still did not respond and a bugcheck was called. system up for 41 mins.
second bugcheck was the same,
driver amdkmdag.sys
Timestamp: Mon Aug 19 10:44:28 2024
looks like the driver hung and a livekernel dump was being made. (microsoft windows error debugging process?)
note: could not read bios info from these dumps.
the only unexpected driver installed was:
RevoProcessDetector.sys Wed Mar 27 23:49:11 2024
the build was pretty good, except for this file was modified: UCPD.sys
here is the info on this microsoft driver:
UCPD.sys is a system component in Windows 10 and Windows 11 that protects users from unwanted file associations being hijacked by potentially malicious software. It specifically targets the Registry keys associated with HTTP, HTTPS URL associations, and the .PDF file association.
As of now, my PC is restarting itself randomly, No BSODs or whatsoever, but what I notice is that the PC components are not turning off, except for monitor, keyboard, mouse that turns off for a few seconds then powers on right after.
I've uploaded the .csv file of HWiNFO64's log with my PC before it restarted randomly.
EDIT: PC restarted when I was away from it so I'm not sure if it BSODed or it just restarted randomly, but I have a minidump generated, also reuploaded the new HWiNFO64 log aswell.
Minidump Files & Log Files (as of May 05, 2025)
Minidump files: Windows Minidump Files (Google Drive Folder)
Log Files: HWiNFO64 Log Files (Google Drive Folder)
system bugchecked because of a call to
nt!RtlIpv4StringToAddressW
with bad arguments.
this is function that converts a ipv 4 address to a binary version of the ipv 4 address. (network related string conversion)
looks like it was given a null pointer to convert.
I do not know why it was called from some random kernel address
0xffff940e`8d4e6ae0
system uptime 1 hour 56 mins
normally, this function is pretty simple and would not fail.
maybe something wrong with page table entry.
(normally that would cause a different bugcheck)
bios is still old version from 2018.
you might consider running intel cpu update:
https://www.intel.com/content/www/us/en/download-center/home.html
I would really try to get the bios updated and look for a cpu ME update.
ie install intel management engine to get the me update to install. you can remove the intel management engine software after the update if you don't want it.
you might want to look up the write endurance for your drive. the newer and larger 480 gb drive has a write endurance of 150 T a smaller drive would have much less write endurance. I think your drive has hit 114T writes. if this is the cause of your failures, then you should replace the drive or disable microsoft virtual memory to turn off the pagefile.sys that is written to disk. Windows will then create a internal pagefile in side of the RAM to handle paging operations. if the errors are coming from the paging operations to disk then your bugchecks should stop.
note: a small drive like a 220gb would have much less write endurance. (maybe 75 terabytes, which you have exceeded)
you might also look for firmware updates to your ssd
120gb ssd version has write endurance of 40T
your drive size should be shrinking as the drive firmware finds and marks blocks as bad. some old drives have firmware bugs where the firmware does not get to run when it should. this is often fixed by a firmware update or you can boot into bios and leave the drive powered on for a few hours. after 5 minutes idle the drive firmware should start its repair functions, marking blocks bad.
deleting old files from the drive can extend the drives life since it will give the firmware more good blocks to move data to from bad blocks. You want to have as much free space on the drive as you can.
if you wipe the drive, be sure you power it up for a few hours before you reinstall any thing on it. (or there will be strange slowdowns for days, until the drives cleanup routines complete.)
with bad arguments.
0xffff940e`8d4e6ae0
I've downloaded and checked for updates using Intel Drivers and Software detector, and here's the result below:
Also, I assume that you think that there's a problem with my SSD (where the OS is installed)?
Here's the result also by using Hard Disk Sentinel.
I've recently found out that my SK Hynix is not working when it's the only RAM stick installed (whether Slot 1 or 2). The PC just powers on and the GPU light is blinking randomly, unlike before that it was beeping (can be resolved with eraser).
I've also used an eraser to test if it will still work but there were no chance of making it work in either slots, only the HyperX works on its own in every slot.
I've tried installing 2 RAMs at the same time (HyperX and SK Hynix), and the computer still boots up despite the behavior of the SK Hynix when it's the only one installed.
is there a reason you do not update the bios to the current version?
2018 bios is really old. lots of cpu security fixes since then.
last bugcheck was
PROCESS_NAME: MemCompression
STORE_DATA_STRUCTURE_CORRUPTION (1c7)
The store component detected a corruption in its data structures.
Arguments:
Arg1: 0000000000000000, A chunk heap buffer's hash doesn't match.
Arg2: ffffd587eaff5000, Chunk heap buffer whose hash didn't match.
Arg3: 0000000021c0e153, Expected buffer hash.
Arg4: 00000000002feff5, Page frame number of the corrupted page.
system was up 1.5 hours or so.
