manwithnoshoes :
I upgraded to 10 right as I bought the new parts. I'm in the process of going back to 8 right now (updates are being difficult), so I'll see if that does anything. I'm just worried that this is some underlying issue with my parts that will come back later to haunt me.
Also, just wondering, what could cause newer hardware to run less efficiently with a certain game? The game's engine?
1) I can't recommend going back to W8. There's nothing in W10 that will make your game run noticeably worse. The fact that the benchmarks and other games works validates the hardware works fine as do your drivers.
2) come back to "haunt" you?
Not sure what you mean there.
3) Performance drop...?
Normally I'd say a CPU issue but your benchmarks results are good so that shouldn't be a problem. Again, other games work so...
I'm a little baffled as it really seems to be the game itself but then you say it was better before.
*When you say performance drop, by roughly HOW MUCH are we talking in a somewhat repeatable scenario?
(Dropping from 80FPS to 20FPS or 80FPS to 60FPS or what?)
Summary:
I really can't think of a good reason based on your explanations so far why this would happen. My guess would be that the performance is actually identical and you're just looking at a different section of the game or something, but I'm not there so it's hard to say.
