System failure during rendering
kresoo
hello,
i'm not sure is this a software or a hardware problem, but when i try to render a little larger resolution or more detailed model with my cpu, my pc just restarts during rendering, without the blue screen.
my config: i7 6700k, thermalright true spirit 140, gigabyte z 170x gaming 3, 32gb ram, gtx 1070, psu fractal edison M 550W 80+ gold.
i rendered in sketchup with vray (cpu render), but i also installed blender for the test. In bledner when i render with my gpu everything works fine, but when i switch to cpu, the program crashes or screen gets frozen.
On my older pc (i5 3570k, 8gb ram) when i install the same sketchup and vray, and start the same model, rendering works fine. The both computers have windows 10 pro version 10.0.14393
I tested my pc with memtest86 and prime95 (both for 12 hours) and i got 0 errors.
Also i have print screen of my task manager and HWmonitor about 30 sec before failure.
https://s28.postimg.org/5m2eb9ru5/hw_monitor.png
https://s28.postimg.org/ieqib73fx/task_manag.png
im also not sure does it have anything to do with my graphics card blinking led power supply indicator. I bought my pc 4 months ago, and the led light flashes all the time. When i took it to the service center, they tried connecting my pc to a stronger psu, but the light was still blinking. So, they said i should run some benchmarks and if there's a problem the graphic card would burn out, and if it works fine then i should ignore the indicator.
https://s28.postimg.org/9h5sduazx/graficka.jpg
just tried now rendering with an open pc case, and it worked just fine.. so was it overheating?
i mean on hwmonitor cpu temperatures were all under 60 C, and the cpu fan was around 910 RPM, so i don't really understand..
