Hi.
So, I want to mess around a bit with the fan curves in the bios to achieve optimal airflow for better temperatures. I'm using an ASRock Z790 mobo. My system airflow is as follows:
2x Arctic P12 120mm as intake at the bottom
3x 120mm from GPU radiator (Sapphire RX 6900 XT Toxic Extreme Edition)
3x Arctic P12 120mm as exhaust at the top (CPU Radiator for Arctic Liquid Freezer II)
1x Arctic P14 at the back as exhaust.
Case is an E-ATX Fractal Meshify 2 Lite TG.
All the Arctic fans can be controlled trough the BIOS, and the GPU ones are automatic from GPU load.
This means that most of the time, when browsing, watching videos or playing lighter games (Death Stranding per example was really light, GPU fans were off most of the time) I'm running negative pressure. GPU fans will only start sucking in air when GPU gets more load. When playing FH5 (all maxed out at 1440p), CPU will sit around 55°C on average and GPU at same temperature.
So, taking all this in mind, what's the best fan curve I can set? Leave it in performance mode? Noise levels is not a factor, as I can't hear it with headphones, even at top prolonged loads.
