When I plug my case fan into the system fan header on the mobo, it won't boot up. The light on gpu and cpu fan will turn on for just a sec and spin then nothing after. But if I unplug my fan from the header then everything works. Is this a motherboard issue or what? Cause I have my fans running now, just always 100% running cause I can't control them since they're not connected to mobo. Any help is appreciated.
My mobo is GIGABYTE GA-H81M-H LGA 1150 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128693&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Motherboards+-+Intel-_-N82E16813128693&gclid=Cj0KEQiA_fy0BRCwiLaQ5-iFgpwBEiQA884sOeCUeUWzzn5oue_sUHrTZv4wjOddW5s-qIL5SvHvyn4aAv768P8HAQ&gclsrc=aw.ds
The fans are, http://www.amazon.com/Corsair-Series-AF120-Edition-Airflow/dp/B00F6S13DE
