System For $300-$350 USD
roots88
12
hey guys ive decided to get a new mobo instead of the one my buddy gave me. which wasnt worth spending of the cpu
i have this layout of all the parts i want so let me know what you guys think
i just want to spend @ least $350 here are my parts below.
COOLER MASTER Elite RC-310-BWN1-GP Black Steel / Plastic ATX Mid Tower Computer Case$39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119203
SPARKLE SFPC84GS512U2LP GeForce 8400 GS 512MB 64-bit GDDR2 PCI HDCP Ready Video Card $44.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814187042
COOLER MASTER eXtreme Power Plus RS-500-PCAR-A3 500W ATX12V V2.3 Power Supply$39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171031
ARCTIC COOLING MX-2 Thermal Compound$7.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
ASRock G31M-S LGA 775 Intel G31 Micro ATX Intel Motherboard $43.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157146
Intel Pentium E5200 Wolfdale 2.5GHz 2MB L2 Cache LGA 775 65W Dual-Core Processor $65.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler$29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Your mb has onboard video but not particularly good .
If you replaced it with this
ASRock G41M-LE LGA 775 Intel G41 Micro $63
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157144
you wouldnt have to buy the gfx card you have listed .
That saves you $33 , which you could reinvest in more RAM .
A 2 x2 gig kit probably is affordable .
The system wont be capable of gamng , but then it wouldnt with an 8400 gs either . Later you can add a gfx card and then it will .
I'd not buy an aftermarket cooler and thermal grease, core 2 duo runs really cool, with stock cooler you can easily get 3.6G up unless your room is an oven. with the money you saved, get a better graphics card.
