Build Advice System for esxi tutorial lab
Mar 15, 2019
Hi all,
I plan to buy server or good workstation (Z800, Z420) for testing and learning esxi virtualization. So I was looking and found some system witch I think it can good for start.
1. https://www.newegg.com/Product/Product.aspx?Item=9SIAC0F8R60340
2. https://www.newegg.com/Product/Product.aspx?Item=9SIA8WV4RD5753
  1. https://www.newegg.com/Product/Product.aspx?item=9SIAC0F7UC7424
  2. ...or something better ...
budget is 300~400$.
I mix server and workstation because at the moment I will keep test esxi pc in office and maybe is easy to take Workstation home then server and keep in bedroom (less noise and wife will not kill me :) ).
Thanks in advance
