$2000, AMD or NvidiaWhat's you budget?
AMD or Intel?
AMD or Nvidia?
Intel Core i7-9700K 3.6 GHz 8-Core$2000, AMD or Nvidia
HiIntel Core i7-9700K 3.6 GHz 8-Core
MSI MPG Z390 GAMING PLUS
Corsair Hydro Series, H115i PRO RGB, 280mm.
G.SKILL TridentZ RGB Series 32GB (2 x 16GB) 288-Pin DDR4 3200MHz
EVGA GeForce RTX 2070 SUPER 8 GB
Intel 1TB 665P M.2-2280 NVME SSD (main disk)
4TB 3.5" (backup /storage disk)
Cooler Master MasterBox MB530P ATX Mid Tower
Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX
AMD Ryzen 7 3800X 8-Core 3.9 GHz (4.5 GHz)
MSI MPG X570 GAMING PLUS
G.SKILL Trident Z NEO 32GB (2 x 16GB) 288-Pin DDR4 3600MHz
Found the adjustment in the bracket...are you avail if I have further questions?, and thanks...specs are out, and I should have an elite fs2020 setupHi
Hi joejesa..
I went with your Intel suggestion..but I am having trouble mounting my pump to my processor..the Intel bracket holes are not correct spacing, nothing to attach to with the amd?..can send pics if you are willing to help, or suggest more appropriate forum
..thanks...msi mpg z390, intel i7-9700k, corsair h115i?
Thank you sir...I did the msi mpg z390 , so i had onboard video, windows install went great...and i went with the Alienware 27 Gaming Monitor - AW2720HF . gpu is physically in, haven't powered yet, so i may be back with more ???..thanks for your help and advice, it sure surfs the web fast🆒I usually test the system with the iGPU and if it works then I install the GPU.
What's your monitor budget?
