Exported System Information:
https://www.dropbox.com/s/kwwegurcub1kedq/sysinfo.txt?dl=0
Ever since I installed a new game from steam "Holdfast: Nations At War" I am routinely getting a full system lock-up. Whatever is on the screen remains there - no black out or artifacts. Mouse input stops working. And I can't access task manager. I am forced to hit the restart or shut-down button. In-game or watching youtube this has occurred. But last night I was on the phone for 6 hours and my computer was left alone and no freeze occurred.
There is no BSOD, so no dump file to go over.
And the only events in the viewer are ID's associated with me having to force a restart or shutdown manually.
Fans are ok.
Temps are ok.
I updated NVIDIA drivers.
I updated RealTek Audio drivers. (irrelevant I guess, I use an external audio interface)
I checked my Bios Version, it was the latest.
I ran memtest for 12 hours with no errors.
EDIT:
Ran WD's DLGDIAG and my system HDD passed extended test.
Ran chkdsk (/f specifically)
Updated RealTek Ethernet controller driver
Updated USB 3.0 host controller driver
Updated Sata host controller driver
Updated Steinberg Drivers for UR22 interface
Uninstalled ALL NVIDIA audio controllers (but they keep showing up in device mngr!!!)
Disabled RealTek audio (USB > UR22 > Studio Monitors || so RealTek is irrelevant I guess)
A friend recommended to reinstall .net framework and Direct X. It could be completely coincidence that the issue started after installing that game, but I figured I'd give it a try.
Upon running the .net framework installer from Microsoft it tells me my version is up to date and I can't continue with the install.
And when it comes to manually installing direct X I am a bit confused. So many of the newer versions (v11+) are limited by your OS version. And the default download on Microsoft site is still the old 9.0c version. I am not sure what to do with these.
Based on these symptoms I am looking for input so I can prioritize and execute the diagnosis.
What should I focus on ruling out? CPU? GPU? MOBO? System files?
Again, the only software changes that took place was that game. My system was perfectly stable before the game was installed.
thanks for any input
Fans are ok.
Temps are ok.
EDIT:
