System Freezes, Getting too many bsods like its a normal routine and sudden reboots
hackerz217
43
Hello,:)
i am experiencing a issue in system,i started having these problems a few days ago which are:
1.Too many BSODS(i.e services exception,bad pool etc)
2.Sudden Reboots and when it restarts it says that the system has recovered from a serious error.
3.Data corruption(system restarted during disk check)
4.CPU goes to 100% and freezes.
5.Sometimes it does'nt even start when power button pressed.just a blink in the light next to power L.E.D which belongs to HDD L.E.D.
i did a memtest just to be sure if their is any fault in memory modules but they passed like 39 tests if i remember correctly,overall it said test PASS so i think memory modules are ok.
My system config-Intel g2020,Zotac GTX 750 Ti 2gb, Dynet 6 GB ram at 10600, Foxxconn H61 Mxe-v,
8 TB HDDS(2 TB Toshiba, WD Black 3 TB (SE Edition), 3TB Seagate SE Edition),A simple 450 watt PSU.
Any help is appreciated.:)
psu is ok,i did i power requirement check and it turned out that psu is providing the sufficient amount of power.and i did repaire windows.please elaborate if their is some issue regarding that.
i dont think that heating is the issue cuz i anm using 2 cooling fans other than the stock fans.
what are the chances of my motherboard being faulty?
its a zebronics 450 smps (ZEB-450),cpu here isnt the only issue,m getting BSODS all day,sudden restarts etc,second thing is cpu automatically shuts itself down if it sense some critical temperature which didnt happen in my case which concludes that it isnt an issue of overheating.
If the mobo was faulty generally you'll get a beep code or an LED readout code or, most likely, it just wouldn't work at all. Weird symptoms, again, I have no clue. Unless the CPU itself is failing somehow, or the OS's HDD. I don't know on this one. The only other things I can think of is maybe a driver is out of date causing a conflict that pushes your CPU into high gear until it shuts down/reboots because of temps, or a virus does the same. So you need a test bench, other than that, to isolate the faulty link in the hardware chain. Or as I said try a fresh install of whatever OS you use. You seem to know PC stuff yourself. See what I mean? Or open the task manager when it does work and try to watch the processes and see which one pushes your CPU to 100 percent when that starts to happen.
i have fix the issue of BSODS, now the problem is that whenever i turn on my system ,it starts and shuts down the very next moment 2 or 3 times in a row, and yes,my led light did blinks sometimes when i turn it on.(feeling horny
😉),the disk usage goes to 100% no matter what i execute,my os drive is 6 years old,its an SE edition and with 100% health and performance,i think my motherboard is failing.
