I recently installed 32gb of Corsair Vengeance RGB PRO ram into an x370 Gaming Pro from MSI. I was tweaking the RAM to run at the highest speed regardless of latency, (I believe I had c18 before problems started happening). when I booted windows up again the system would freeze for 20-30 seconds and briefly start working again, this repeats. The CPU and GPU weren't under load and I have a sufficient psu of 700w. I have reset my ssd and installed windows again, removed hdd, switched out ram, changed speed to default etc. BIOS is up to date
Here are my system specs:
MSI Gaming Pro x370
RTX 2070 Founders Edition
Ryzen 7 2700x
32gb Corsair Vengenace RGB PRO C16
256gb Samsung Evo Pro 970
1tb Seagate Ironwolfe @ 7200rpm
Thermaltake White 700w
MSI Gaming Pro x370
Ryzen 7 2700x
