Question system holding at b1 error for 10 minutes after shut down and starting.
pc-reliable
34
This is Wired, But it is happening.
system holding at b1 error for 10 minutes after shut down and starting.reset button tries also stops at b1 error before 10 minutes, passin after 10 minutes on at b1 error, and pressing rest button allowing the bios to windows.
recent power cuts made this situation, before power cuts system is working fine
no matter if I am on stock or overclocked speeds it is the same.
any solutions are so much helpful
i7 5820k 20gb ram
970 gpu
asus x99 a mb
960 pro nvme ssd for windows 10
repair or reinstall windows installation.
Hi thank you for the suggestion,
Tried it twice
repair(couldnt found any repairs) and
reinstall using nvme ssd, still same problem.
I uninstalled the OS ssd and all hdds and kept only a os from pendrive to install and a ssd to install it. still it is stopping at b1 error, not even booting into the pendrive.
These are current troubleshootings done
repai not worked,
reinstall not worked
unplugged all drives except one drive to install os and pendrive to boot OS install, not worked
Your description isn’t very well done so how about you post pictures of what’s going on. It’s obviously a hardware issue
you stated power outages caused issues, right? it is possible it fried the psu or mobo or other devices.
