System idle process HIGH cpu usage
mrmirror
Hello everyone,
I need help please, my CPU usage is very high at about 95%, and it seems system idle process its causing it.
Honestly i`m not too good at it to know what to do to solve this problem
I`d attach my Process Explorer report if it might help, just could find a way to do it
sorry
i`m running windows vista 32bit
Thanks a lot in advance !
mrmirror
Thanks for your reply Z1NONLY
I`m using microsoft security essentials, found nothing
i also ran a scan on spybot search & destroy, and thisone found nothing as well
ive done it one at a time, just as you`ve said
Thanks!
jfreggie
111
13
System Idle Process always shows the unused percentage of CPU..... so showing that it is using 95% means all the tasks you are running are only utilizing 5%... everything is very normal.
mrmirror
it shows me 900MB out of 1GB memory being used
Thanks!
mrmirror
i hope you`re right..
thank you
mrmirror
i`m not too sure where i need to check thatone
all i can see is in task manager/performance: physical memory
total 1021
cached 337
free 0
is that what you needed to know?
Thank you
mrmirror
excuse me, i meant to say "my physical memory usage is very high at about 95%, and it seems system idle process its causing it."
CPU looks OK, its at 20%
Thank You
mrmirror
