System interrupts high CPU spikes, audio stutter, freeze.
Pinshivic
Commendable
Jun 27, 2016
13
Hello, I recently built a new computer and I've been having this problem, so I'm usually working on photoshop while watching a stream/video on my other monitor, when suddenly the CPU spikes, sometimes the PC completely freezes for about 3 seconds max and the audio stutters and crackles, sometimes only the audio stutters, I know it's probably due to driver issues and high DPC, but the thing is that these spikes happen very little that I haven't been able to monitor with LatencyMon or Windows Performance Recorder, It's pretty annoying it breaks my concentration when I'm working, I have been trying to fix it for the past week, still struggling.
I have tried clean windows 10 install, only running the graphics card and network with different driver versions and still get spikes. I usually have very low DPC, around 20-70, but these spikes are killing me.
I have sound and HPET disabled on my motherboard while using a logitech G430, tried disabling turbo-boost, still had the spikes.
I don't know if I may have 2 different issues since the DPC/ISR and Interrupt spikes usually don't cause CPU spikes and don't produce the issue.
My rig:
CPU: Intel Xeon E5-2670
Mobo: Intel DX79TO
GPU: PNY GTX 750 Ti
16GB Ram HyperX Fury @1600Mhz
500GB WD Caviar Blue
I don't think any USB device is causing the issue, since when I only had mouse and keyboard I still got the DPC/ISR/Interrupt spikes.
Sometimes I manage to catch the problem while looking at the task manager since I almost always have it opened and I see that when the CPU spike happens the usage comes from the process system. Which makes this super confusing for me since I believe it should be the system interrupts process.
I appreciate any thoughts on my issue.
Hello... I have three devices listed for my 16... In the OLD OLD days, this would/could be a problem... But these days, I seldom even look at them. If you would like to play with interrupt settings, in the MB BIO's and the Device manager-properties-Resources. I have READ in other Audio forums that a AMD card did help some users with their MB resources and latency. B /
http://forum.cakewalk.com/default.aspx typically I read "The Studio" hardware and Computers sections, try a info search there.
I'm gonna check that right now, thanks for the advice!
So the BIOS didn't had any of those options and the windows services regarding bluetooth and wifi are all disabled.
Hello... 1) do you have any red or yellow marks in your Control panel-Device manager?
2) what Realtek model chip do you have?
3) Whose (owner) of the driver that is listed... And what version #? Control panel-Device manager
4) What is the audio output bit/freq are trying to run? Control panel-Sound
5) What is you audio connections and typical use? anything 'special" or out of the norm?
1) I do not have any marks in the device manager
2) The realtek audio is disabled from the BIOS I couldn't find the model of the chip. I use my G430 Headset which has it's own soundcard.
3) Realtek and 6.0.1.7240 / Logitech 8.83.51.0 (for the G430)
4) 16 bit, 48000Hz
5) The g430 USB soundcard
With any of the devices I still get the spikes, also I have the NVDIA HD audio driver installed for when I want to use my monitor speakers.
Hello... It is known that some MB's have higher Latency and Spikes than others... you do have a high end "special" intel MB, but I have No actual Data/experience with. The Audio has to be processed by the CPU with either card/chip (software device)... can you post a image of your data you collected so far?
4b) have you tried 24 bit/44khz or 24 bit/48khz with both devices?
6) do you have "core parking" disabled? win10 setting available? utube it.
7) Have you tried the OS setting to background services? Control Panel\All Control Panel Items\System\advanced system settings/advanced/performance settings/advanced-adjust for performance of background services.
8) Here is info that get passed around in the cakewalk forum http://www.blackviper.com/service-configurations/black-vipers-windows-10-service-configurations/
9) Go into all your Communication and OS APPS... under preferences Disable any Auto update/file searches and never.
6) I didn't had parked cores
7) Just adjusted that, let's see if it solves the problem
8) I'm gonna take a look at that
9) I already have all updates disabled
Gonna see how it goes with the background settings changed to performance and I'll report back, it might take me a day to see if the problem comes back as it doesn't happen very frequently.
Thanks for the help.
Also let me get a good pic of the LatencyMon and what I can find.
So here's what latencymon looks like.
When the sound stutter and freeze happen is when Highest measured interrupt goes extremely high, usually from what I can tell when the DPC goes high, nothing happens.
Also storport.sys only gets that high since I did a clean install of windows 10.
Before that it would usually be another random driver.
So after a lot of testing and almost 2 days without having the trouble, I have come to the conclusion that the conflicting driver is USBPORT.SYS still haven't found a solution.
Heres the latencymon stats:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:03:09 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: VICTOR-PC
OS version: Windows 8 , 6.2, build: 9200 (x64)
Hardware: Intel Corporation, DX79TO
CPU: GenuineIntel Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
Logical processors: 16
Processor groups: 1
RAM: 16308 MB total
CPU SPEED
Reported CPU speed: 260 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 2066.044910
Average measured interrupt to process latency (µs): 4.199061
Highest measured interrupt to DPC latency (µs): 2062.500418
Average measured interrupt to DPC latency (µs): 1.079381
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 138.404231
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.038624
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.075956
ISR count (execution time <250 µs): 313595
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 5988.643462
Driver with highest DPC routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.083588
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0.217937
DPC count (execution time <250 µs): 1193756
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 1
DPC count (execution time 1000-1999 µs): 4
DPC count (execution time 2000-3999 µs): 1
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 296
Hard pagefault count of hardest hit process: 142
Highest hard pagefault resolution time (µs): 69481.554231
Total time spent in hard pagefaults (%): 0.041433
Number of processes hit: 6
PER CPU DATA
CPU 0 Interrupt cycle time (s): 3.021647
CPU 0 ISR highest execution time (µs): 0.0
CPU 0 ISR total execution time (s): 0.0
CPU 0 ISR count: 0
CPU 0 DPC highest execution time (µs): 90.838846
CPU 0 DPC total execution time (s): 0.623584
CPU 0 DPC count: 560078
CPU 1 Interrupt cycle time (s): 2.160852
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 104.341154
CPU 1 DPC total execution time (s): 0.004178
CPU 1 DPC count: 763
CPU 2 Interrupt cycle time (s): 1.924459
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 93.910769
CPU 2 DPC total execution time (s): 0.077014
CPU 2 DPC count: 22615
CPU 3 Interrupt cycle time (s): 2.236446
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 121.332308
CPU 3 DPC total execution time (s): 0.035366
CPU 3 DPC count: 3845
CPU 4 Interrupt cycle time (s): 2.135053
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 139.323846
CPU 4 DPC total execution time (s): 0.159255
CPU 4 DPC count: 13849
CPU 5 Interrupt cycle time (s): 2.040968
CPU 5 ISR highest execution time (µs): 35.129231
CPU 5 ISR total execution time (s): 0.010481
CPU 5 ISR count: 1883
CPU 5 DPC highest execution time (µs): 98.7350
CPU 5 DPC total execution time (s): 0.013005
CPU 5 DPC count: 2827
CPU 6 Interrupt cycle time (s): 2.070368
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 126.820385
CPU 6 DPC total execution time (s): 0.076378
CPU 6 DPC count: 8681
CPU 7 Interrupt cycle time (s): 1.971521
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 104.038462
CPU 7 DPC total execution time (s): 0.003690
CPU 7 DPC count: 516
CPU 8 Interrupt cycle time (s): 1.863697
CPU 8 ISR highest execution time (µs): 0.0
CPU 8 ISR total execution time (s): 0.0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 152.766538
CPU 8 DPC total execution time (s): 0.050793
CPU 8 DPC count: 6285
CPU 9 Interrupt cycle time (s): 2.007455
CPU 9 ISR highest execution time (µs): 0.0
CPU 9 ISR total execution time (s): 0.0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 82.5950
CPU 9 DPC total execution time (s): 0.013926
CPU 9 DPC count: 2103
CPU 10 Interrupt cycle time (s): 9.688131
CPU 10 ISR highest execution time (µs): 138.404231
CPU 10 ISR total execution time (s): 2.221911
CPU 10 ISR count: 304737
CPU 10 DPC highest execution time (µs): 5988.643462
CPU 10 DPC total execution time (s): 5.339058
CPU 10 DPC count: 549878
CPU 11 Interrupt cycle time (s): 2.066497
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 80.1250
CPU 11 DPC total execution time (s): 0.029060
CPU 11 DPC count: 2618
CPU 12 Interrupt cycle time (s): 1.926844
CPU 12 ISR highest execution time (µs): 0.0
CPU 12 ISR total execution time (s): 0.0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 89.008846
CPU 12 DPC total execution time (s): 0.047473
CPU 12 DPC count: 5867
CPU 13 Interrupt cycle time (s): 2.527983
CPU 13 ISR highest execution time (µs): 58.946154
CPU 13 ISR total execution time (s): 0.064709
CPU 13 ISR count: 6975
CPU 13 DPC highest execution time (µs): 93.597692
CPU 13 DPC total execution time (s): 0.019605
CPU 13 DPC count: 3279
CPU 14 Interrupt cycle time (s): 1.870822
CPU 14 ISR highest execution time (µs): 0.0
CPU 14 ISR total execution time (s): 0.0
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 95.949615
CPU 14 DPC total execution time (s): 0.049869
CPU 14 DPC count: 5867
CPU 15 Interrupt cycle time (s): 2.232735
CPU 15 ISR highest execution time (µs): 0.0
CPU 15 ISR total execution time (s): 0.0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 121.154231
CPU 15 DPC total execution time (s): 0.048712
CPU 15 DPC count: 4693
Ok, so now I figured that USBPORT.SYS spikes were caused by my headset microphone, didabled it and now the spikes occur with either NDIS.SYS, NVLDDMKM.SYS or DXGKRNL.SYS, If I disable one, another one causes the spikes, I think that the spikes only happen when watching youtube videos, still not sure about that.
Already did that, just installed an SSD and the problems persist, I think it passes from driver to driver in latencymon but the actual driver that's causing the problem is the network driver, I'm gonna be testing with different driver versions and see if I get any freezes/audio glitches with the SSD.
So I just found that my graphics card and a USB controller have the same IRQ PCI number, I think that might be causing the issue.
But I cannot disable the USB driver and I obviously need my GPU.
