I've seen a couple other threads on this, (a few got suggested) but I just want another opinion, I'm planning to replace the RAM and Power Supply next week (the RAM was always giving me problems - imo - and the power supply is definitely old)
The system specs:
Ryzen 5 2600x
Corsair Vengeance Pro RGB 16 GB
ASUS Rog B450-f Strix
3 x 1tb HDDs, 1 Kingston 120 SSD
GTX 1060 6GB that I'm holding for dear life because buying a GPU in these times is scary.
So it doesn't happen always, it happened just now and the system had been on for 70+ hours so far, but no crashes. Windows pushed through an update that's about it.
I've gamed a bit during the time, mostly been a lot of Crusader Kings, and I noticed epic had 2K21 free so I picked it up and was playing that a bit. Got no freezes over the weekend, but this morning I was playing 2K again, and got up to go do something, came back, and the entire system had frozen and I had to hard restart it.
I'm willing to bet it's the RAM or the PSU, because the PSU is an old 450 (I literally don't even know the name or anything, but it's not a "known brand" he told me) I'd bummed from a friend a few years ago and I never bothered to replace it because it kept ticking, and RAM because I have absolutely horrible luck with RAM. This batch refuses to clock to anything above 2133 on the XMP profile. Even if I do it manually, just doesn't boot.
My temps are still good, the inside of the case isn't overly dusty, it has some dust was gonna wait until I get the new PSU to clean it out and just rebuild from scratch.
Also, why I'm thinking it's the PSU or at the very least hoping it is. When I turned it on Friday night, it would load through the bios well enough but as soon as it got to windows the signal died. I waited but it never recovered and I ended up hard restarting twice before it actually came on, and I never turned it off since until it crashed this afternoon, and it booted right back up.
So I'm leaning towards those two components and I'm gonna change them out ASAP, just wondering if anyone has any other thoughts. Nothing shows up in the event viewer when it freezes, most I got was some information panels telling me that the
Processor (#) in group 0 exposes the following power management capabilities:
Idle state type: ACPI Idle (C) States (2 state(s))
Performance state type: ACPI Performance (P) / Throttle (T) States
Nominal Frequency (MHz): 3600
Maximum performance percentage: 100
Minimum performance percentage: 61
Minimum throttle percentage: 61
Any other opinions would be greatly appreciated, and I am hoping very much that it's not the GPU lol.
The system specs:
Ryzen 5 2600x
