Hi folks -
I'm new to overclocking, and I've tried to do all of my research but I'm still a little bit confused about the effect of the FSB😀RAM ratio - and how I should be setting this on my new system.
I have a Gigabyte P35-DS3L board with a 6600 (B3 Stepping) and 2 1GB sticks of Corsair Ballistix RAM (800mhz, 4-4-4-12, 2.2v).
Right now, I have my CPU Host Frequency set to 333, which gets me an overclock of 3.0ghz. I'm comfortable at 3.0ghz for the moment - but I do plan on trying to get this higher if I can. I'm using a Scythe Ninja Rev B, and I've heard that this CPU should comfortably overclock to 3.2 with this cooler.
As far as memory is concerned - I've set the memory timings in the BIOS to 4-4-4-12 and set the voltage to +.4v. Right now, I have the "System Memory Multiplier" set to 3.0. Things seem stable, but I'm worried that they aren't "ideal". I have read that your FSB😀RAM ratio should be 1:1, and CPU-Z lists mine at 2:3.
I'm kind of at a loss as to what I should be setting this to in order to obtain the golden 1:1 ratio. Also, will this setting have to change as I increase my "CPU Host Frequency"?
Thanks.
- Keith
Thanks.
- Keith
