Just wondering. I assembled my computer some time ago - and recently we hung it up a wall so there is more room on the desk and under - also, the case allowed for wall hanging and it looks kind of neat - just in case you are wondering why one would hang a computer on a wall.
Since then, i noticed that the computer is anything but silent - or rather, i only noticed that it was actually pretty loud, when i heard something "winding down" last night .. which i would guess ... must be some fan. There are quite a lot of them in the system. But i cannot figure out which fan it is .. i tried going really close to each fan .. and they are all very silent. Maybe someone has a suggestion what might make a winding noise in a computer.
again - the problem is not so much that it hums .. its when it stops humming and you realize how loud it has been. One actually gets used to the humming
- Thermaltake c3 (or p3?) case, which sadly is open to all sides, but looks kind of pretty
- an Arctic 280mm cpu cooler with a little fan on the pump but it really is tiny - this one is still quite new. Only got it like half a year ago
- a quadro rtx 5000 with a single fan that rarely spins at all it seems - this one is old, i think - we got it used with very little information about its former usage
- a fan that we glued on the heatsinks of the motherboard to cool down the chips around the cpu - not sure if that is the culprit - but it does not "wind down" .. it is plugged into the "case fan" plug and seems to spin all the time regardless - my suspicion is that this must be it. It is the only fan that spins all the time ... and it is not installed correctly but only glued on.
- a seasonic connect - with the hybrid mode enabled (i think it is hard to reach the button) and i think the fan rarely spins or never really has. - This one is brand new, i do not suspect it to make any noise.
