System Not Booting Up
Jun 23, 2018
6
This is the first pc i built.
It worked fine for a couple of weeks.
One day I was browsing on the net when suddenly the display turned off.
Then i restarted the computer.
The bios is showing up but after that windows is not booting.The screen just goes blank after the initial mobo logo.Another observation was after the mobo logo shows up the gpu fans stop spinning.
In case of requirement the computer specs are
https://pcpartpicker.com/list/hzdgP3
Also i think there is no problem with ram because it is showing up on UEFI
By the way UEFI can be accesed
It could be the RAM speed. That RAM kit is not listed in the ASRock QVL. At which speed is the RAM setup in the BIOS?
In G.Skill site is listed as "Programmed for the Intel platform".
If you are able to access the BIOS, change the RAM speed to 2400MHz.
Jun 23, 2018
6
The ram speed shows up as 2400MHz in OCTweaker Page and 2133MHz in overview page.
Also I noted that on removing GPU and connecting HDMI to mobo it wasn't even showing the UEFI.
Jun 23, 2018
6
THANKS A LOT DUDE.
I was highly worried because I am from India and i couldn't exchange parts even if they were damaged.
I guess resetting the cmos is the best option.
I think the problem arose due to me using 3 y splitters.
i knew something was wrong because the cpu temperature was higher than usual 3 fan setup.
Thanks a lot again.
You're welcome
If that solved your issue click the "Pick as the solution" button
By the way, a fan header usually delivers 1A (unless otherwise is specify) so check the fan specifications, to avoid drawing more power than the header could deliver.
If you have 0.30A fans you could run three fans from a fan header.
But if you have 0.41A fans then you could run two per fan header.
