System on SSD freezes for 5-10 minutes
Jan 2, 2019
Hello. I have a laptop with sdd Kingston SKC400S37/256G installed instead of stocked hdd. And hdd installed with special adapter instead of dvd. I'm using Windows 7 64-bit. Here is a thing: after clearing recycle bin system don't do anything for 5-10 minutes. I can only switch between opened apps windows. Music player also stops. CPU and RAM aren't loaded. After freeze all comes back to normal. The same freezes are happening while finishing downloads from internet, cutting files from ssd to another storage(flash or hdd or phone). The bigger file gets deleted or cuted the more time system doesn't respond normally. I think it is caused by ssd itself. What can be the solution for this problem? Thanks
Similar threads
