My PC won't power on unless I open it up, remove the CMOS battery then put it back in a minute later. Only after I do this will my PC even power on telling me I need to go into BIOS. Once I do this, Windows 10 pro boots up and everything seems normal until the next morning when I need to turn on the PC again.
I just put in a new CPU (5700x3D) and added 2 more sticks of memory plus installed a Thermaltake watercooler for the CPU. I also used Arctic MX-6 thermal paste.
Did a fresh install, made sure all wires are connected properly.
I've searched around online and some people have the same problem, but no way to fix it until they replaced a motherboard or power supply.
I'd like to add this has never happened prior to upgrading my CPU and adding new sticks of ram plus a new water cooler. My old CPU was a Ryzen 5600x running on 8GBx2 ram and heatsink/fan for the CPU, Windows 10 Pro.
What can I do besides pull my hair out and buy new components?
My system is below
AMD Ryzen 5700x3d
GSkill 8Gbx4 DDR 4 memory 2133 MHz,
ASUS B550 Rog Strix motherboard with latest BIOS just flashed.
2 M.2 sticks at 2tb each.
1 Sata SSD 1tb
XFX 850W black edition single rail power supply (purchased beginning of 2016)
My system is below
AMD Ryzen 5700x3d
1 Sata SSD 1tb
