System performance equality - what GPU works in tandem
plebiscite
I'm making this post first to show that I can follow directions and I read up on rules etc. so :
APPROXIMATE PURCHASE DATE: this week ,the closer the better
BUDGET RANGE: USD $150
USAGE FROM MOST TO LEAST IMPORTANT: Gaming - Minecraft, CS:GO, dirt, Folding@Home, home theater/watching movies
CURRENT GPU AND POWER SUPPLY: nothing yet
OTHER RELEVANT SYSTEM SPECS: core i3 2100, MSI 77a-g41 LGA, kingston hyper x red 1600 MHz 2 sticks of 4GB Ddr3, Kingston hyper x SSD 128 GB.
PREFERRED WEBSITE(S) FOR PARTS: newegg, tiger, eBay
COUNTRY OF ORIGIN: USofA
PARTS PREFERENCES: nvidia/asus
OVERCLOCKING: Maybe SLI OR CROSSFIRE: No
MONITOR RESOLUTION: none yet
ADDITIONAL COMMENTS: value/ best bang for buck is most important in the nvidia family
REMEMBER: The more information we have about your system, your budget, and what you're using the card for, the better the advice we can give you - providing it up front gets you your answers and puts a card in your hands that much faster!
Include a list of any GPUs you are currently considering or would like opinions on.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121446
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121435
And now a little blurb to better explain and for those who like to read :
Hello,
I've read literally dozens upon dozens of threads here about different computer parts and finally found myself at a point in my build where I am unsure where to go next.
I'm building a middle-ish grade desktop pc and I find myself wondering what parts of my build will exploit the best aspects of each other.
The very basic question is : what GPU should I get?
So far I have core i3 2100, 8 GB ram, Z77 MSI motherboard, Kingston 128 GB SSD. And now I'm picking the graphics card. I will use the computer for everything but primarily for web browsing and new video games that I haven't been able to buy/play since All I've had is an old dusty crusty Sony pc from '04 :)
I have had my eyes and heart set on nvidia gtx 560 as it had a very high value per dollar rating. But the more I read stats the more I realize its quite a decent card and I think it may be better than or " out-perform " my system build to the point I won't be able to use what I buy and with a slower processor I might as well just get a gtx 650 instead. Especially considering the power draw the 560 needs.
And I am brand new to computers, can someone tell me how this card is powered? Does it take 2, 6 pin power plugs from the PSU?
Thanks!
Wouldnt be overly concerned about bottlenecking on this rig. Only in CPU intensive games (which most arent) will the card be held back by the processor.
At your price point, theres the GTX650Ti and HD7850 1GB (Not much point getting the older Fermi cards).
http://www.anandtech.com/bench/Product/549?vs=680
As you can see, the 650Ti gets outperformed by a large margin by the 7850. It also has stronger compute capabilities, which will help on your Folding@Home performance.
The 7850 also outperforms the 560Ti.
http://www.anandtech.com/bench/Product/549?vs=547
Here's the card I recommend.
Sapphire HD7850 1GB. $175 ($10 rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202004
or if your willing to max the budget, the reference 2GB model of the 7850. $210 ($15 rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102999
How many connectors it will require depends on the card. But the 7850 I linked above takes one 6-pin connector, while a 560Ti requires two.
If you can afford the Asus GTX560, you'd be better of with AMD 7850 1GB card (or maybe the 2GB version as well if there's a great deal).
If you only want to spend around $150 however, the best choice is the GTX650ti (faster or similar than a 560 without high AA and lower power consumption)
