System power consumption.
Aviano
How do I calculate system total power consumption, I want to figure out what my 320 watt ps can support.
Generally required system wattage is determined by your GFX card.
1. Use PSU calculator in above post
2. Look up GFX card manufacturer's system requirements ....
nVidia - http://www.geforce.com/hardware/desktop-gpus
Click on Card / Specifications / Scroll down to Thermal and Power Specs
AMD - AMD has gotten a bit shy about posting their system power requirements since the R7.R9 series.
3. Google "Guru 3G [your GFX card]", go to review, use drop down to find power consumption. For example:
http://www.guru3d.com/articles_pages/radeon_r7_260x_r9_270x_280x_review_benchmarks,10.html
Here is Guru3D's power supply recommendation:
AMD R7 260X - On your average system the card requires you to have a 450 Watt power supply unit.
AMD R7 260X Crossfire - On your average system the cards require you to have a 650 Watt power supply unit as minimum.
AMD R9 270X - On your average system the card requires you to have a 500 Watt power supply unit.
AMD R9 270X Crossfire - On your average system the cards require you to have a 700 Watt power supply unit as minimum.
AMD R9 280X - On your average system the card requires you to have a 550 Watt power supply unit.
AMD R9 280X Crossfire - On your average system the cards require you to have a 750 Watt power supply unit as minimum.
If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina.
