I have noticed my temperature goes up to 65 degrees on idle except chrome wit a single PDF tab open. it doesn't always stay like that. my usual idle temps around 36degrees Celcius. whenever i hear my cooling speed up pressing windows key and closing down makes it go away. I am also having around 70-75 cpu temps during(Arma 3 - BO4)mostly any games.
PC Spec
-I7-7700k
-Aorus Z270x-Gaming K7
-Corsair H115i 280mm
-Corsair Crystal Series 570x
-16gb 4x4 Corsair Platinum 3000mhz
Overclock
i have oc'd my cpu to 4.6ghz around 1.215core voltage
PS: I had to drill my case on top to make my liquid cooling mounted on the top to have good airflow since i want to use my case's own rgb intake fans. I can provide images if needed
PC Spec
-I7-7700k
Overclock
