Hello everyone,
I'm buying a system before the end of the year and I could use some advice on whether I need to wait for or exchange anything. I've put this together :
MOBO: ASRock Z390 Taichi Ultimate https://www.newegg.com/p/N82E16813157856
CPU: Intel i9 9900K https://www.newegg.com/p/N82E16819117957
GPU: ASUS RTX 2080 https://www.newegg.com/p/N82E16814126339
RAM: Patriot Extreme Performance Viper 4 https://www.amazon.com/dp/B01E1XR5X6
PSU: Seasonic FOCUS Plus 650 Gold https://www.newegg.com/p/1B4-01KF-00036
COOLER: Noctua NH-U12S https://www.newegg.com/p/N82E16835608040
CASE: Fractal Design Define R6 ext. ATX https://www.newegg.com/p/N82E16811352091
I already have storage. It will be transferred from the old machine. A Samsung 850 EVO 1TB SSD, a Samsung 830 Series 512GB SSD and 4 TB storage.
I need the features of the Taichi as I utilize most of its features. I have 10Gbit net at home and 600/600Mbit internet and use 6x USB-A and 2x USB-C.
I'm not sure about i9-9900K vs Ryzen9 3900X. (Taichi comes in an AMD variant as well)
I'm not sure whether RTX 2080 is the way to go or if I should sacrifice the extra to go Super, if it's worth it.
I'm not at all sure whether I have the right RAM.
I'm confident the current system will only require ~560W.. 608W with TDP in consideration(according to PSU calculators online).
The NH-U12S should be sufficient for my needs and is cheaper than the NH-D15 which would've been the alternative.
I'm a lot about a simple sleek effective design so Fractal Design is almost non-negotiable, but if you can find other cases that embody this spirit, go for it.
It will be used for streaming and gaming. The monitor is an Asus PG279Q and will run at 165hz G-sync when possible. It will also be used for VR games.
