System rating problem
oriench
8
hye there....
i have a problem in rating my laptop performance...it can't be rate..while the rating was running..then, it suddenly stop and a message appeared..it state that my computer can't be rating due to the incorrect parameter...and, "your computer window experience index has not yet been established" what that message suppose to mean?? i don't understand b'coz this is the first time i brought laptop on my own...what should i do to fix this problem...?any idea?/.
What mcnumpty23 recommended is worth a try.
I think windows error would state " on battery power and insuffeint time remaining" Also on battery power if it runs, the scores may be lower than when on AC power.
You indicated that it starts and the bombs out at some point - At which point does it stop.
The order of tests are displayed and I think the order is:
.. 3D tests
.. Media decoding
.. media encoding
.. CPU test
.. memory test
.. Disk test
hye......thanks for replied my mssge...
i did plugged in before rate my computer...
at the first assesmnt, i run normally until it reached
the test on memory disk....it stop and state that ' the system could not be computed' - error: could not measure the storage performance. failed to properly assest the disk.the parameter is incorrect...
the statement was pop-up when it stop suddenly...
so??? anything that i can do to repair it..other ways rather than format n re-install the system...please help me!!!
tq-
can you tell me how to run the 'checkdisk'... heeee..
i just brought this laptop....it's eee pc seashell series(asus)..mini-laptop...
disk C = 68.8 gb n disk D = 98.7 gb...
go to start and type cmd in search--open the command prompt thats listed by right clicking and select run as administrator--in the command prompt box type chkdsk /f and say yes when it says cant lock the drive as its in use do you want to schedule checkdisk--then restart pc and checkdisk should run 0n reboot
Also can find cmd swithes by entering chkdsk /?
"On free space: you said "disk C = 68.8 gb n disk D = 98.7 gb"
is that free space or total space ?
If you go to my computer and right click the drive and then select properties, it will show Used space, Free space, and total size.
