System Repair Loop
OrigD
48
Hello
As the title says the computer boots up however, it will attempt to run Windows but as soon as it does the logo will freeze mid way and then the system immediately shuts down and restarts. This is a new build and I haven't been able to actually get into the system at all as of yet. One issue that adds to this is the fact that the mouse and keyboard both stop working as soon as either windows boots (I see the LED's all go out) or when I attempt to run Startup Repair (though they both work in BIOS). I can't attempt to go into safe mode as the computer only gives me 2 options: start windows normally or launch startup repair.
I have attempted to reinstall Windows 7 so that I could maybe see if that solved the issue however, once again, the keyboard and mouse turn of at this stage. I did put the HDD in another keyboard and reinstall Windows and attempted to use it with a fresh install however, the issues remains.
Any help is greatly appreciated.
Many Thanks
SPECS:
Motherboard: ASUS ROG STRIX B350-F Socket
RAM: Corsair CMK8GX4M2B3000C15 Vengeance LPX 8GB (2x4GB) DDR4 3000Mhz CL15 XMP 2.0
Processor: AMD Ryzen 5 1600x
CPU Fan: Hyper TX3 Evo
GPU: AMD Sapphire R9 380 4gb
PSU: 500W
1TB Hard Drive
Did you check with ASUS to see if you need anything special to run Windows 7? There are no audio drivers for 7 for that motherboard listed from ASUS, it's really not meant for older Windows.
Yeah I should have done my research a bit better, messaged ASUS and they said essentially the same thing. Said I should go to Windows 10 so there is no compatibility issues.
Many Thanks.
