System Resources
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
On Window 98, how do you increase system resources free to 90%? (I tried doing CTRL+ALT+DEL but it was not enough.)
Why?
Didn't you pay for that memory?
Wouldn't you like to use it?
<b><A HREF="http://www.seti.tomshardware.com/" target="_new">How fast is your PC</A></b>
That's the beauty of Windows. You have no real control over it, and you will never (legally) be able to see what it's actually doing.
Aside from that, you can run a number of programs to 'flush' things out to the page file. Turbomem (Memturbo?), Tweakall, APK are just a few that will do that for you. There's a way to do it manually, by making a .vbs file with a single command, but I forget how.
In your startup, make a few things load as possible.
Windows is a big memory eater; it'll take it away from you if you don't put it to use yourself :)
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
Run msconfig and look at all the programs listed under the startup tab.
You can uncheck anything you don't need, if it causes a problem you can always 'recheck' it.
If you run msconfig, don't forget to put a dot next to selective startup under the general tab. Then remove your startup programs. systemtray and scanregistry must remain checked
Windows uses a large amount of system resources for itself so it is hard to say if you will ever get it to 90% free. i run with 256Mg of ram on ME and i rarely see more that 75% free
The system resources in the windows family is such thing in which it is like RAM, software takes it, and some never returns it(unless u reboot), when it runs low, your com locks up. This has been a "bug" of the windows 9x family, no improvement is made even in ME, but i think NT/2K is using a diff method, and therefore, MORE STABLE.
oh yeah the memory managers in win nt and 2000 are streaks ahead of the 95/98/me ones. they have to be to give better stability. although i have to admit windows me is running pertty well. i sometimes have up times of 4 or 5 days. nothing like my months in linux but still impressive for windows.
